Approach to Hull Paragon - February 1985
An incident at Hull, on the approach to Hull Paragon involving a Met-Camm and a Class 108. A track circuit fault allowed the points to be moved under an outgoing DMU to Beverley. The train then sideswiped an incoming DMU from Scarborough which had just started to move under clear signals.
Images by Mrs B. Fleming.
DMU cab against middle section of derailed vehicle DMU leaning on its side with another leaning against it
February 1985
Collision
Involving Class 108 / Met-Camm
Information from Ian Fleming and Neil Mackay
